Judge64
To Isata 3 Freedom Edition Owners Only
I thought I would share this link in case any of you have not seen it yet. I found it a few weeks ago but revisited it again today after a few others posting on the Facebook site about some electronics / communication issues they experienced on the Freedom Edition recently. Xantrex has published eGen information specifically for the Isata 3 on their website so here is the link.
Dynamax ISATA3 eGEN
I also suggest you consider installing the same Bluetooth Remote Panel for the Freedom Pro X/C 3000 that I have been using for a few years and also installed on my Freedom Edition after I picked it up last month. It helps with troubleshooting and setting changes for the Inverter / Charger as well as accurate real-time status information. While we go through some growing pains it can simply your life.... including just power-cycling the Inverter from inside the coach. Eventually things will settle down and there will be little interaction with the Xantrex Display Panel..... but until then this can make things easier.
You can get it on Amazon and other suppliers.
Home
Dynamax ISATA3 eGEN
Home
