A Locked Rotor is a compressor failure, so the AC will pull the 61 amps if the rotor is locked up...
So I just found the attached info from a company that makes an EasyStart solution called Micro-Air. Now they may just be publishing this data to sell more of their product but according to this chart a 15K BTU can surge 65A at startup. They do put a disclaimer that specs will vary by A/C manufacturer.
So for arguments sake....
65A Start x 110V = 7150W
Lets say the C-M takes 55A to start then it is ~6000W and within the spec but it would be nice if C-M published this data to know for sure.
So lets take it one step further and assume the attached chart is marketing propaganda that it takes 60-65A to start a 15K unit and its just wrong. Then let's just look at a true locked rotor situation.
Lets assume the A/C is running and shore power is interrupted (briefly or long-term). It could be an EMS detected that shore power voltage was too low or simply the power just went out. Several of us with C-M units have seen E03 errors when shore power goes out with the compressor running. The E03 is an inverter overload situation.
A few of us have determined that there isn't a Compressor Start Delay in the FireFly or the C-M unit itself to prevent short-cycling.
If the inverter is not switching over fast enough to keep it running and the compressor stops.... and then immediately tries to restart when inverter power comes up.... you would have a situation where the compressor is locked up from the pressure being too high trying to restart immediately after shutting down..... a short-cycle.
If you have the inverter set to Auto Restart after an error, the Inverter may try to start up the compressor again after the E03 error clears. It will do so up to 3 times before finally shutting down and requiring an inverter reboot to clear the error. This is what a few of us have seen happen with the C-M units. It can take 1 1/2 - 2 minutes for the pressure to bleed off.... but the inverter auto-restarts happen very quickly so the E03 error makes sense.
When this happens the surge would be 62A (according to your document) x 110V or 6820A or about 13% over the inverter surge spec.
Does this mean anything at all in terms of the inverter failures some of us have seen? Is it contributing to some of the inverter failures? Maybe or maybe not. There isn't enough data to be certain.
It could just be a bad batch of inverters.... but a SoftStart could rectify the E03 error when shore power is interrupted while the compressor is running. It would also reduce the stress on the Inverter when starting the compressor.
All I'm suggested is it may be worth some investigation and lab measurements of the average startup surge of the C-M unit and also the surge when there is an interruption of shore power and the inverter tries to take over running the compressor.
The SoftStart TSB is for the GE Units but this discussion is indicating there are several C-M units out there and many of us have seen the E03. And the only inverter failures I have seen reported on this site and the Facebook site are with the C-M units..... so far.
