A couple of days ago I had a chance to do more testing. The panels had been producing very little power for a good number of days. At most 2 watts on occasion. And prior to that it was only getting a max PV power of 5 to 9 watts. In fact since the panels appeared to creep back to life for a few days in mid-February the output was dropping again even with many days of full sun.Another data point. I tested with a folding portable 200 W panel. Just laying flat on the ground I was getting better than 20V open circuit and about 7 amps short circuit current. Since none of the GoPower panels were giving me more than .2 amps short circuit current it definitely looks like the panels are toast.
I'll pull the slide in and take the portable panel up on the roof and spread it out, and connect it to the MPPT just for one last test.
I'm hoping that this is just a fluke with the production batch of GoPower panels for whatever reason.
So I got back up and unhooked the front driver side panel and tested it again. In full sun it was only producing between 5 an 6 volts open circuit. And 0 amps short circuit current.
So I took my folding 200 Watt panel up on the roof and laid it out. The folding panel was producing about 22 volts open circuit and 7 amps short circuit current.
Next I plugged the folding panel in taking the place of the front driver side GoPower panel. Almost immediately the Victron app showed solid output from that panel. I only had it connected for maybe a max of 30 minutes. During that time it produced a Yield of 60 watt hours, and a max PV power of 126 watts.
So pretty conclusive that the GoPower panels are toast. The one appears to be almost totally dead, and the other two are really not much better.
So this is definitely added to my warranty list for the trip to Dyanamax.
