Starlink Installation
I have been using Starlink for over two years and it works great so I have been trying to figure out how I wanted to install it on the Isata 3 Freedom Edition.
I really wanted to install the Router in the cabinet above the fridge and then run the data cable out the hole in the floor used for the Truma Combi drain behind the Power Control Center. But after several attempts of trying to run a wire with a Fish Tape, I determined the fridge would have to come out to get the data cable run properly. It doesn't look that hard to remove the fridge but I started looking at other options.
I finally decided on installing it under the bed with the remaining space I had left after all of the other upgrades..... and so I could take advantage of the ventilation hole under the bed for the battery compartment to run wiring. I did some signal tests and the bed enclosure and mattress don't hurt the signal-to-noise much at all so I decided that was an easy place to get it installed and give me the flexibility I wanted with Dish placement.
I already had the Xantrex Optional GFCI Outlet that I took off my Super C and installed that for AC power for the Starlink Router. Then I ran a short extension cord through the ventilation hole under the bed and installed a smart outlet so I could easily power the Starlink Router On or Off.
The I bought a mounting kit off Amazon and used Velcro to mount the power supply and the Router itself. I also got a CAT8 extention and ran it down to the battery compartment so I could plug the Starlink Dish into it there.
But after thinking about it.... the easy way was not the best way. I don't always want to leave the battery compartment door open. Bugs, mice and snakes could get into the battery compartment and then into the ventilation hole under the bed.
So I think am going to install a female connector with a waterproof cap where the Black and Grey Tank drain controls are located. I can use a 1" hole saw to cut a hole and mount it where I have the red arrow in the picture below. It is wide open behind these controls under the coach and easy to access. I can run the data cable out the hole in the battery compartment with all of the other wiring already there before I seal it up permanently with spray foam.
So this upgrade is still a work in progress but close to completion.
I thought about mounting the Dish on the roof with a quick disconnect mount but after using Starklink for over two years having the flexibility to move the Dish in heavily wooded campsites is important. I also didn't like the idea of having to pull out the ladder to get off the roof and put it back on if I needed to move it for better coverage.
I opted for the FlagPole Buddy Hitch Mount. I had their Ladder Mount solution and it worked well so this is a good alternative with a ladder. This will allow me to put it up in the air and still have the ability to put the Dish on the ground to move around the coach for a better line of site if needed because of tree cover.
Here is the mount I purchased for the Router and power supply....
https://www.amazon.com/dp/B0D12QWX59?psc=1&ref=ppx_yo2ov_dt_b_product_details
Here the link for the CAT8 extension with female connector....
https://www.amazon.com/dp/B0BL3YMB2B?psc=1&ref=ppx_yo2ov_dt_b_product_details
Here is the link for the Xantrex Optional GFCI Outlet.....
https://www.amazon.com/Xantrex-Free...1720901194&sprefix=xantrex+gfci,aps,98&sr=8-1
Here is the link to the CAT8 outlet I am going to install in the Black / Grey Tank Control compartment......
https://www.amazon.com/dp/B0BMFBJTTG?psc=1&ref=ppx_yo2ov_dt_b_product_details
Here is the link to the FlagPole Buddy Starlink Hitch Mount Setup….
https://flagpolebuddy.com/products/ols/products/gen-2-or-gen-3-starlink-hitch-kit
