campfirefun
- Joined
- Jun 17, 2010
- Posts
- 177
Anyone put led lights in ceiling fixtures of trailer. Wondering if you have to remove whole fixture or just plug in new bulb. What sources are there if this is possible
there are literally hundreds of posts here on LEDs.
a quick search will give you hours of reading and info, without waiting for others to post.
KQ2N said:Since I dry camp almost exclusively, to not wear down the coach batteries, I too switched to LEDs throughout. I got mine on ebay, I looked for "warm white", I think around 3000 or 3500 degrees K (kelvin). I think I got 18 of them for around $30, shipped free, from China. I've used them one season, no problem so far. I was just down to a RV store this morning, they're still $15 to $30 EACH depending on which one you buy.
BigBaron said:On Amazon get the 18 LED bulbs (5050 LEDs) they are the only ones I've had that are equal to a standard 921 bulb. LED Wholesalers are great for quality and help.
I put together a wish list for LEDs on Amazon.
Amazon LED choices
I have bought almost all of the lights except for the really expensive ones. I next am going to try the panel lights, especially the 5050 ones. I have been warned that some of the cheap Chinese ones get so hot they melt!
Remember to put aluminum foil tape on the inside of the dome light!
BigBaron said:If you have a wedge base (T10). If you have a bayonet base, they have those too.
I saw today at the dealership that the RV manufactures are in the LED game now and make a LED light factory. The housing looks like a normal one but the LED is a huge dot! bigger then a quarter! and on the backside inside is a block that the wires run into and is the power conditioner for the LED's.
Also replacement housing with 2 LED's is $26, individual LED is $19!
Has anyone used these flexible LED strips?
WFLS-x series Weatherproof High Power LED Flexible Light Strip | LED Strips | LED Light Strips & Bars | Super Bright LEDs
Thinking of using them as under cabinet lites in the home and trying them in the RV.
Just wondering about how much lite they give you, real task lighting or are they more like accent/mood lites?
