BlackLabRebel
- Joined
- Jun 15, 2024
- Posts
- 5
I've seen this problem reported on several other forum threads, but never noticed a resolution. My Control Panel Monitor LED's will flash for 5 seconds after attempting to turn on light, water pump, or awning. Just like described in the "Troubleshooting" section of Lippert OneControl Monitor Panel Owners Manual. (https://forestriverinc.com/files/Co...- OneControl Monitor Panel Owner's Manual.pdf).
The manual states that this is due to an interruption in this data network (i.e. harness compromised) will result in a fault. Besides verifying that the power harness is securely attached to the back of the monitor panel, which I (and several in other threads did), there is no solution given in the manual.
Anyone else aware of the solution? Will replacing the Monitor Panel Assembly fix this, or is it a deeper problem somewhere else?
