As the title says, I have a Lippert rack and pinion slide on my 2011 Rockwood 2604. While washing it to put it to bed for the winter, I notice both slide skis are cracked. I have news skis on order, but during some investigation as to how the slide works, I found I have a slide strip (plastic/nylon?) that the bottom of the slide rides on vs rollers. The bottom of the slide has what appears to be a fiberglass panel that slides on the slide strip. The panel is getting some drag marks on it. I wondered about possibly waxing the slide strip and the fiberglass panel to make it slide with less friction. Has anyone done this? I saw an article about slide lubrication at RVEnthusiast Magazine about lubing both. They advocate spraying Blaster Dry Lube with Teflon on both where they meet. I can see where this would do a good job of lubricating, but have concerns about the lube rubbing off on the carpet inside the camper. If I am going to do something, I would like to do it when I have the slide jacked up to replace the skis. I am open to suggestions, as this is the first time in the 11 years I've had this camper that I had to do anything to the slide.
TIA
TIA
