NXR
The vehicle manufacturer puts the max psi on the sticker because they have no idea what load the vehicle will be carrying. So they say pump em' up to max.
You have no idea what you're talking about. Try reading FMVSS 120 and you'll learn why you are wrong.
The pressure on the sticker for vehicles in excess of 10,000 lbs GVWR is mandated by law to be the minimum pressure in the tires installed by the vehicle manufacturer in order for those tires to safely support that axle's GAWR, its gross axle weight rating a.k.a the axle's maximum design weight.
That's it, nothing more and nothing less.
If the pressure on the sticker matches the pressure molded into the tire sidewall for vehicles over 10,000 lbs GVWR that just means the tires have no safety margin at all.
Ray
