Looking for someone who has a 360 with outside TV
Sbryant
Nov 22, 2013
434
Quitman MS
We just purchased a 2014 Georgetown XL 360 and have successfully installed and connected our satellite system. However have not been able to figure out how to watch the satellite on the installed outside TV. Anybody done this? Can you tell me how? Thanks.
Shirley
Thanks for any potential help out there. Hubby just told me he just figured it out. When all else fails, try, try again.
Shirley
It's brand new ( like we have had it home for 2 days) and its so different from our old motor home which we had had for 10 years and it was totally personalized to fit us. Realistically tho I think because it has a separate air antenna built in behind it he just didn't think it would connect to the satellite.
Shirley
Just picked up our 360 XL on Saturday haven't had time to play with TV's yet got real cold hear in PA. but cant wait. I will be hooking up SAT to our TV's how did you solve this problem.
Thanks Bldhnd
Unhooked the "cable in" cable and hooked it to the "satellite in" on the receiver box, then ran another cable from the receiver "to TV" to the "cable in" on the selector box. Then moved the switch on the selector box to "cable". All four TV's then showed the same problem.
Note: problems I had to fix
With the hot water tank filled with water and driving home, the painted outside of the body "poked" out at the bottom a couple of inches - very unsightly for a brand new motor home - due to the weight of the water in the tank. I had to fix it with braces underneath.
The entrance door "dragged" very bad, making noise and also making it hard to open and close. I ground down the "bead" on the door where it was dragging and scratching off the paint.
If you need to contact me - sonbryant@hotmail. com
