LP Gas detector.
Not sure of your rig, or if you have the 2017 Cardinal 3250RL. LP Detectors are almost never run through the fusebox.
Cardinal actually has a decent electrical schematic/writeup available (though it's old and likely not applicable). Still, if they published this, they might also have published one for your 2017, or are availlable to call/email and ask.
In the meantime, this thread might help:
https://www.forestriverforums.com/forums/f22/propane-leak-detector-fuse-location-235971.html
The OP found his LP detector to be run through one of three 3amp fuses found at the battery.
Mr Dan is also correct, many have also found a fuse immediately behind the detector.
Just my .02, hope this helps.
