boubou
- Joined
- Jul 5, 2010
- Posts
- 1,355
prof_fate said:If you do some component investigation you may find the issue, or assure yourself there isn't one.
Could be a light duty trans or transfer case or axle that's causing the rating to be different than expected.
My expy is essentially an F150 and rated to tow accordingly. But for put the 4R100 trans in the Expy's in 2001 - that's their big momma tranny so it can tow almost anything. I've not investigated the transfer case, but Iv'e got an AWD system..not a normal truck option. It moves the power to the front wheels as needed at any speed...nice idea and it works, but at times I've had it clunk hard (say, starting on wet grass or gravel when the rear wheels start to spin). Add 10,000 lbs to that and I'd guess component life would be shorter than a traditional transfer case.
I've made my peace with using Dodge body builder specs tosee what I cam tow. The Dodge site knows the specs of the Ram QC SLT p:
GVWR 6700
Payload 1310
Truck weight 5362
GAWR 3900 front and rear
GCWR 14000
Max trailer 8450
20 inch wheels, if go down to 17, all I gain is 50 lbs payload
3.55 gears
Of course, I went to the scales and got the loaded numbers and withnthe help (and patience) of manynon this forum, I find that The Ram cantow my 5800 lbs loaded TT
Never mind changing gears 3400 lbs max !!!!!!!
