HONDAMAN174
We get this all the time: "well Autozone said..."
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
This is why there are 30 pages of warnings in a 33 page product manual.
Just got a Monday customer on a Thursday.
We just had a customer come in here wanting us to swap some tires out on some rims he had.
Problem is, he started the process on his own, with the bright idea to cut the tires off the rim...I guess not realizing there is still wire in the bead bundle.
Now here is where you get to start laughing and shaking your head. His next great idea to remove the bead bundle was to use........ drum roll please......... it's going to be good...........I promise you........ are you ready....... a cutting torch.
Well, the only thing he actually succeeded in cutting through, was his aluminum wheels..... as we pointed out to him.![]()
And how was he planning to remount the tires on his own?
Believe it or not, my wife's uncle's neighbor has an old tire mounting machine. You never know what's hiding in someone's tool shed!
Got one in the shed and inserts in the garage floor to anchor it.
LOL I almost bought an old 4040 Coats one time... it was real cheap.. Idunno $1-200 and worked fine. I just didn't. Shop got all new equipment.![]()
Just put of patent curiosity, have you ever used it?.....
Thats an 'Armstrong Tire Changer'. and it's worth about 49 bucks tops.
I prefer hydraulic cylinders and a motorized de- mounter myself
In the old days - To dismount a tire, used a bumper jack set on the tire (next to but not on the rim) and jacked the car up to break the bead. Turned the wheel over and did the same to break the other bead. Removed the tire with tire irons and a hammer. Soaped the rim to lubriicate. Mounted the new (typically used or repaired) tire with the hammer, one bead at a time. I probably did twenty tires this way "in my youth". I would then loosen the brake adjusters so the wheel turned freely and rotate it by hand (car jacked up), and let it self rotate to find the "heavy spot", adding wheel weights opposite until the wheel did not self rotate at any position - balanced!
Back then I also used blowout patches for big holes or tears, and tubes...
A manual tire change "machine" was a luxury - the one I remember had two curved (about 10 inch long) jaws hinged so they would clamp the tire on both sides at the rim, and a several foot long handle for leverage - just used to break the beads.
Sure looks easier now at the tire shop...
