Probably none so than other retailers. I try to just talk about the funny/interesting ones. You most likely would rather hear about the train wrecks, than the normal boring flow of traffic.Your customer base is quite interesting.
For sure!Probably none so than other retailers. I try to just talk about the funny/interesting ones. You most likely would rather hear about the train wrecks, than the normal boring flow of traffic.
You have normal customersProbably none so than other retailers. I try to just talk about the funny/interesting ones. You most likely would rather hear about the train wrecks, than the normal boring flow of traffic.
I am wondering that too...............................You have normal customers??????
Lots of them. Abby Normal.You have normal customers??????
haha. Such a great movie. Side note, if you do an image search for "Abby Normal" be prepared for what results you'll see. People wearing their birthday suits rather than bunny suits. Just a warning.Lots of them. Abby Normal.
On 4x4s you often have to change all four tires if you ruin one. Also many change out to custom rims and tires are often changed too...... New car take Offs that have low miles.....How do you have so many used tires? I can't be the only person that gets new tires when the old ones are fairly worn out.. down to the wear bars at least. I'm sure you see a couple dozen customers each day, and someone will always want to swap out for some newer, more aggressive, etc... It seems every week you have a story of selling someone a used tire(s). And you always have their size. Does every one in Louisiana use Michelin model XGV, size 75-R, 14-inch wheel?
There are actually used tire distributers/wholesalers.How do you have so many used tires? I can't be the only person that gets new tires when the old ones are fairly worn out.. down to the wear bars at least. I'm sure you see a couple dozen customers each day, and someone will always want to swap out for some newer, more aggressive, etc... It seems every week you have a story of selling someone a used tire(s). And you always have their size. Does every one in Louisiana use Michelin model XGV, size 75-R, 14-inch wheel?
When I needed a tire repair about a month ago the only place that was open on a Sunday was "..... Used Tires"There are actually used tire distributers/wholesalers.
As far as having the right sizes, that is wishful thinking. I probably miss about 2/3 rds of used tire sales by not having the size they need. The customers purchasing used tires are majority those with older vehicles. They also tend to run their tires down to the air.. It seems every week you have a story of selling someone a used tire(s). And you always have their size. Does every one in Louisiana use Michelin model XGV, size 75-R, 14-inch wheel?
Blasphemy!!!! Never ever plug a tire!! LolOur maintenance guys at the campground found this on their work truck this morning. The tire did not lose any air until they pulled it out. And yes they "plugged" it! BTW in case you can't tell it's a wire wheel/brush for a drill.
Shame about the tire. That wire brush has seen better days though.Our maintenance guys at the campground found this on their work truck this morning. The tire did not lose any air until they pulled it out. And yes they "plugged" it! BTW in case you can't tell it's a wire wheel/brush for a drill.
“…found this on their work truck this morning.”Our maintenance guys at the campground found this on their work truck this morning. The tire did not lose any air until they pulled it out. And yes they "plugged" it! BTW in case you can't tell it's a wire wheel/brush for a drill.
Probably couldn't tell over the vibration from the massive woofers.
And being oblivious seems to be commonplace nowadays.
