Johnfort
54 Years, 13 RV's
Will my Jackery 1000 be able to properly charge from the "Battery #2" output terminals on a GoPower PMW 30. I plan on adding a 12V SAE plug in the interior to plug the Jackery in.
I know solar has been around for a bit, so before LiFePO4 batteries, what setups did rv'ers use? Starting with 3-500 watts on top to type of controller, and what type of batteries. I'm pretty sure people boondocked somewhat back in the day.
The same GC2s you're using. Some use AGM because there's little to no off-gassing, meaning you may not need ventilation to keep them indoors.I know solar has been around for a bit, so before LiFePO4 batteries, what setups did rv'ers use? Starting with 3-500 watts on top to type of controller, and what type of batteries. I'm pretty sure people boondocked somewhat back in the day.
The only issue in the previous correspondence is that it sounded like you intended to add a 2KW inverter in addition to the existing 1KW. The result (3KW) would be too much.
Have you read the The 12V Side of Life? You'll find it informative. It's dated but most of what the author describes is basic lead-acid information, and will never change.
Makes sense. Thanks.Your Jackery 1000 has a built in MPPT controller. You would be stacking a PWM controller on top of a MPPT controller. Plug your solar output straight to the Jackery. As long as the solar panels are within the limits of the Jackery you'll be good.
Can it be done? Yes, but it should not be done as the two outer most batteries will be out of balance when drawing current from them as well as charging. The inverse is the two middle batteries will be having more current passing through them and it will “abuse” them more.
In order to balance them in the scenario you presented the batteries would need balancing cables/buss bars. People don’t do this as it adds cost, complexity and hassle when the cables can be tapped off the outer most posts. Make sense?
Another question, I'm sure I know the answer, but will ask. The cables from the charge controller to the batteries, hook them to the same terminals, on each end? Thanks
this may be sort of a dumb question, but can you pull the pos/neg off the circled ones, just as well as the ends like the pic shows? Thanks
