DJ252
- Joined
- Jul 21, 2023
- Posts
- 844
I agree with others, as to the hows and whys of it and that a 150 / 1500 class truck, properly equipped and loaded, will be ample.
The properly equipped and loaded part could get sticky though.
You'll want at least the mid sized engine of that issue and toward the top, of the rear end gear ratios. A 2.7L engine, coupled with a 3.31 rear end, probably won't do.
Also, not necessarily "loaded". Such things as moonroofs, power tailgates, non stock wheels and tires etc. all weigh something, will make a big difference and enough of them on the same truck, can otherwise cripple a 150 / 1500 class truck for heavy towing.
In that regard, buying an existing truck, new or used, is much easier than ordering new. Check the capacity and window stickers, go to the tow guides for that year and you'll have a definitive answer at that moment.
And just to drive it home, the published towing capacities on trucks are a bit of smoke and mirrors. They're real, in the sense of pulling and braking power but in practicality, payload, will be the primary limiter.
And you don't necessarily want or need the "max tow" but you will need at least the basic tow package.
I don't know about others but from 2021 on, F150 max tow, actually costs 20lbs. of payload and has a high failure rate of a critical bolt on that axle. For them, the basic tow package, is the better choice.
