Thanks to all for the welcome!
I made a trip back to the dealer today for a few more measurements and observations. These aren't areas where Andersen can help you. You have to supply the information in order to select the correct parts within your hitch package.
The ground to inside of the hitch cup measurement differed from the number provided by Sahall. Perhaps his is raised for boondocking or it has higher profile tires.
Also this trailer is 1/2" into the range for Andersen's "raised brackets instead of the standard brackets. Their wording is "may" require... I opted for the kit with the standard 3, 4,5,6" bracket because the raised bracket only appears to offer about 1/4" of relief from potential contact with the ground. That seemed like a pretty remote possibility.
The final dimension you need comes from the height of the receiver on your tow vehicle to determine if you need the 4 or 8" rise / drop shank. The 4" works in my case. That, along with the 2 5/16" coupler size on the trailer adds up to the Andersen 3350 Hitch.
The one thing that I won't know until I install it is if the chains are long enough. They suggest that the frame brackets be installed at a point on the A frame approximately 27 to 29" from the center line of the ball cup of the coupler. That space is occupied by a welded in place mount for the LP tanks. The free space is two inches back from there. I think the standard chain length will likely work, but if not I will have to buy the chain extensions.
Regarding the Andersen hitch. Yeah, I decided on it before the trailer. I've had and older Reese with the ball platform welded to the shank and an add on friction anti sway. It got a thumbs down on it's first trip. After that came the Reese Dual Cam. Not bad but there is the popping noise and a bit of a pain to disconnect in some camp sites. At least I didn't require disconnecting anything in order to back up. The simplicity of hook up and disconnection drew me to the Anderson and the added benefits of self adjusting sway control and the no bounce properties and the reasonable price closed the deal. I think I could install it blind folded, so I'm looking forward to the hitch arriving and then installing it on my new trailer.
Thanks again!
