Jimbo542
- Joined
- Sep 10, 2016
- Posts
- 103
Roofing Membrane
I have a roll of Xtrm PLy PVC roofing membrane Leftover. Let me know how much you need and I ll see if I can measure it. It may be 50 I have to check. I switched over from the suplex brand. Here s the specs:
RMA XTRM PLY from LaSalle Bristol is a flexible, durable PVC membrane designed to meet the unique challenges of a RV roof. Unlike other RV roofs, RMA XTRM is a solid material that will not chalk and stain the side of your RV. It does not require periodic expensive re coating. It is naturally fire retardant and UV resistant. Once installed, this membrane is easy to patch/repair with PVC cement. Designed to be installed with RMA adhesive, sealants and butyl tape only. Thickness of this durable PVC material is 27 mils.
View this ad at Forest River Classifieds - New Roofing Membrane
