It's November and the Flagstaff travel trailer is winterized. That was easy. We recently purchased a townhome in Florida for the winter months and are now considering winterizing our main residence in NJ for the 5 or 6 months that we will be avoiding the snow and cold up north. On previous shorter trips, we've just turned down the heat and left the house as is for the cold months. I've rigged a neat video camera that monitors the water meter and will give me an alert if any water is flowing. If a leak is detected, I could then summon a neighbor to turn the water off.
Our plumber/heating guy said that we should really consider winterizing the entire house so that if something happens to the boiler or an extended power outage causes things to freeze, we won't be headed for disaster. The plumber wanted $375 to winterize, and another $350 to unwinterize in the spring. This entails draining the boiler and all heat registers, hot water tank, water feed from the street, ice maker, dishwasher, etc., then blowing nitrogen into the lines and finally RV antifreeze into the traps. It would be a lot easier if we didn't have hot water baseboard heating. Apparently, the water has to be turned on for the boiler to work properly.
What a PITA compared to winterizing my travel trailer!
So my question is, what do all of you seasonal snowbirds do with your northern homes when you're gone for the winter months? I'm tempted to just turn down the heat to 50 degrees and keep an eye on my water monitor and thermostat via the internet.
