Lennyp-FRF
- Joined
- Nov 8, 2022
- Posts
- 19
OK so I have a 2013 forest river cardinal 3800fl ...6 point level up jacks...it has 5 slides but only 3 are hydraulic. It has one big pump and a bunch of valves in the front compartment. In transport it blew a tire and ripped out the rear hydraulic hose on the far real drivers side jack...(black hose) .....do I got it stable the best I could . And I pinched the hose off so that I can open the slides .....so 2 problems ....one is I want to order the hose but the way it goes into the frame I can't for the life of me find the other end because they are sealed in with rubber coating . When I look at how they connect the hoses from jacks to pump every diagram is different so I don't know if the blow hose goes to the middle jack on the same side, the other rear jack, ot all the way to the pump? .....and also I was messing with the valves trying to open the slides .....and I messed something up because now when I hit the slide switch the jacks movee...lol......I really need to find out where that hose goes and what valves should be clockwise and counterclockwise .....any help??? Thank you
