I just got a 2021 Wildwood FSX 177BHX platinum
I have the switch panel
has water pump, water heater , lights lights
and then awning
I have no ceiling lights, and no obvious power to the fridge.
the awning works, Water pump works, the glowy leds on the stovetop work, though it didnt ignite.
Pressing the little check buttons had two red leds for everything unless i had waterheater or pump on
then it showed 3 lights. which is weird . seems to suggest that having those things on somehow creates more power and more water? no idea whats goin on there?
The fans all work, including the fan above the burner, but the light on the fan above the burner doesnt work anymore.
but the no overhead lights thing is bothering me
Whats extra strange is i have a power jack on it and theres a light on it.
and the light on it also didnt work, which is weird to me cause the jack itself worked and i wouldnt expect that it would be a like.
LIGHTS full control that also controlled the jack light.
Its as if all leds suddenly died.
The 12v fridge also had no lights/ power
In summary:
no: Overhead lights, fridge,microwave burner ignition, jack light, stovetop shroud led, AC
Yes: Burner knob LEDS, stovetop shroud fan, overhead fans, waterpump,waterheater , jack up and down, awning in and out.
Furnace unknown cause i had the gas off.
the lights all worked when it was plugged in at the dealership
so IDk what it could be
I pulled my generator over to it to try to plug it in to see if i got a different result but didnt have the right connector and i dont have the converter yet, its in the mail.
I would think if there was a battery cutoff or a fuse somewhere by the battery that nothing would have power
any guidance would be appreciated.
and then awning
In summary:
