jimmoore13
My Propane/CO alarm aged out. In my misguided efforts to quiet the alarm, I cleaned my battery terminals, verified 13.5 volts or so while on shore power, and, and, and... Well, at least that maintenance is done...again.
My rig is a 2020, so I thought aging out was premature. So, in desperation, I "tested" the alarm, and it shut up. The "aged-out" alarm stopped (continuously alternating 2 red and 2 green), and the display went green. Shoulda left well-enough alone, but that's not my style. No-sir-eeeeeee.
In my infinite wisdom I figured I'd blow out the sensor with computer-grade canned air. A bunch of dust came out, but then the alarm sounded a propane alarm. I wasn't too surprised, but I figured it would shut up sooner or later.
As it turns out, the propane sensor DOES NOT LIKE CANNED AIR! The alarm read something in the canned air as a VOC, and it went nuts. I figured it would "dry out" and "air out" so I used the test button to quiet the alarm a whole bunch of times...to no avail. The sensor was NOT HAPPY.
I ripped the thing out of there, and low and behold the date on the alarm is 8/12/19...5 years and 3 months ago. My rig might be a 2020, but my alarm is from the previous decade.
But the point of this is that if you ever get the bright idea to blow the dust out of your alarm with computer canned air, DON'T. And it tells you something about that canned air...not as "clean" as they'd have you believe.
P.S. I did NOT shake the canned air...instructions on the can are very clear about that. It appears to mix propellant with the air. I learned that lesson long ago...the hard way...like every lesson I learn. My replacement alarm is on order from Amazon.
