All this sounds good but how do you explain how dealers operate all the above from JUST THE CONVERTER while the RV is still on their lot and the Trailer's batteries are yet to be delivered for install at the time of sale??????
The slide on my trailer has an actual measured current max of <10 amps whie operating with no solar or converter providing power. My converter is a 50 amp sized unit.
depends on the dealer.... when I did my PDI it was in a covered bay with 120v power available.
but have seen dealers use a temporary battery in the YARD when they need to operate a slide and 120v power is not available.
I have run my slide with only the converter tested it once ... it worked for now...
in the future with age , corrosion at terminals and maybe into the wires..
things like the slides , jacks and stabilizers MAY start to play up.
had issue with my slide a few weeks ago... It would not retract back in
HAD to physically PULL on the slide to get it to move
Not sure of the cause... hall sensors , battery amps or mechanical issue... since it is not doing it again.......... hard to work out what it was?
YES it is possible to remove battery
OR if you want to keep a battery hooked up AND if you are on shorepower all the time ... battery will be always full and won't be a demand on the converter.
choice is up to the user...
Pitfalls and what may happen is outlined in a lot of good posts
