Duggy22
Hello,
I have a Forest River flagstaff 831bhwss 2018. It has been plugged in to shore power all winter. Somehow, over the winter one of the awnings unfurled a little bit so I wanted to roll it up. I opened the RV up for the spring and there is power to the lights, fridge, microwave etc, but the power panel at the front only has a red light on the button labelled "panel power". All the other buttons are off and don't respond. I am unable to use the slides, the hallway light, basically anything controlled by this TP33 V2 panel. Also, the tank sensors do not show any readings. I have tried using a toothpick to reset the panel, but all that happens is the "panel power" button light turns off, the panel beeps, the "water pump" light turns on and after I remove the toothpick the panel power light goes back on and everything stays the same.
I have inspected the fuses in the fuse box underneath the fridge and they all look fine. My GFI plugs in the kitchen and bathroom both work.
When I unplug the shore power and go on battery all the rest of the power works in the RV. I checked to see if the the battery was dead, but it seems fine according to my car battery charger.
I unscrewed the panel and unplugged the Ethernet cable going to the back, but that had no impact and things just returned to red light on "power panel".
From what I have read, I may need a new power panel, but there might be something called a RSB66 black box? That has a 12 pin plug I need to reset I can't seem to find that.
I'd appreciate any advice on how to proceed.
