In 2018 I had an electrician convert my electrical fuse service box to a 200 amp circuit breaker service and install a 50 amp service on side of my garage for my 5er. Other than an initial problem that required the electrician to come back and install a different receptable box, I haven't noticed any problems. I always connect a surge protector from habit when plugging my unit into it even though we have a whole house surge protector at the main box.
This past week my nephew from out of state parked his motorhome in my drive while staying with friends. He plugged in his surge protector first which indicated all was good. However when he plugged his cord in and turned his power on, his on-board EMS shut down and said he had an inadequate ground. He got around this issue by just plugging into a 120 outlet as he only wanted to keep his batteries topped off while parked.
So today I took my multi-meter and checked the wires at the box.
Here are the basic readings I got when the breakers where ON -
Hot1 to Hot2 - 244.3
Hot 1 to Neutral - 122
Hot 2 to Neutral - 122.1
Ground to Neutral - .43
Ground to Hot 1 - 103.3-105.3 (Initially got 89-90)
Ground to Hot 2 - 103.6-105.6 (Initially got 89-90)
Here are the basic readings I got when the breakers where OFF -
Hot1 to Hot2 - .058
Hot 1 to Neutral - 21.4
Hot 2 to Neutral - 21.38
Ground to Neutral - ..65
Ground to Hot 1 - 15.0
Ground to Hot 2 - 14.78
I'm assuming that the EMS was kicking out because of the low voltages when testing the Ground to the Hot legs. I also was kind of surprised at the values I got when the breakers were OFF. I noticed that the ground wire appeared to be connected to the box correctly.
I'm wondering if because it is quite a distance to the circuit breaker box to the receptacle box (even though all the wiring is in conduit & underground) that if I should connect to a grounding rod right at the box as this might correct the problem with the EMS? Suggestions.
Thanks and be safe -
Hot1 to Hot2 - .058
