For Sale: Progressive Industries 30 Amp EMS/Surge Protector - Florida
ForestGump34DS
Aug 20, 2018
306
The Progressive EMS PT30C RV Surge Protector provides high amp; low voltage protection, whenever source power falls below 104 Volts, or rises above 132 volts and will automatically shut down power to the RV. Once the AC source rises above 104 volts, or below the 132 volt level the time delay indicator flashes for the preset time and then automatically restores power to RV.
  • 3 Mode surge protection: This feature provides full surge protection L N, L G, and N G. Joule rating is 1780, response time of lt;1 nano second.
  • Surge Indicator: If ever a power surge damages the surge protector circuit within the EMS L N, or L G Digital display error code will read E 10. This is your indication that it needs to be replaced.
  • Reverse polarity protection: If source is a reverse polarity condition, the EMS will not allow power to the RV and the error code will read E1.
  • Open neutral protection: If the source has an open neutral condition the display will not light, and will not allow power to the RV.
  • Open ground protection: If source power has an open ground condition the EMS will read an error code of E2 and will not allow power to the RV.
  • AC Frequency Protection: If source power frequency deviants / 9 hertz from 60 cycles per second the EMS will shut down source power, and indicate an E7 or E8 error code on the digital display.
  • Accidental 220V protection: If 220 volts is detected when plugging into source power the EMS will not allow power to the RV. If this condition occurs while power is applied to the RV, the EMS shuts off power instantly. The display will read the voltage and the appropriate error code.
  • Integrated information panel: Scrolls continuously all of the power source information, voltage, current, frequency, error codes, and previous errors. Each reading is displayed for 2 seconds
  • Previous error code: This feature tells the user why the EMS previously interrupted power to the RV. This is only displayed if an error actually occurs and goes away when power is disconnected.
  • Whether resistant: Can be exposed to elements, may not be submerged.
  • Microprocessor controlled: The computer, is driven by state of the art microprocessors that are programmed with software to drive the entire EMS.
  • Built in Lock Bracket: Allows the user to secure to power source to prevent theft.
  • Warranty: Lifetime Manufacturer Warranty
  • Dimensions: 5" W x 3" L x 16 1/2" H
  • 10 Gage Wire
  • Made in USA.
FREE SHIPPING......
View this ad at Forest River Classifieds - Progressive Industries 30 Amp EMS/Surge Protector - Florida
