Last time I was out, a trip down to Texas, the 5th wheel went airborne on a really bad bump in the road on SB I-39. The rear outdoor kitchen took the brunt of the force on the Arctic Wolf 3660SUITE. The mini fridge broke loose, busted several bottles of Sam Adams as well as some of the shelves and drawers. Needless to say the beer leaked out too. So today I removed the fridge, and took the shelf out that supported it. There was a white wire attached to the shelf, an apparent ground wire. I got the shelf out and it is bent at one corner from the bad bounce, and I may leave it out. However the panel on the rear wall behind the fridge only goes down so far, and if I leave out the panel I have a loose wire.
Before I assume anything, the wire bundle is exposed, so how do I determine if it is the DC wires and which are the AC wires? It looks like there is Romex and there is also split wire, where the pair separates apart. Is the split wire the DC? They are connected using crimp caps, and not very well, so I may recap them using a better connector. I just want to make sure its DC before I go messing with it.
