First post here, please bear with me...
Our R-Pod 192 is in the early beginning stages of this:
https://www.forestriverforums.com/forums/f197/rpod-frame-bent-244234.html
Let me start by saying we really like the R-Pod from a user perspective, but after 2 years and about 10,000 miles, it has become apparent that the frame and running gear are a bit undersized for the task given the construction methods used. Disclaimer: this is my opinion based on a mechanical engineering degree and decades of custom fabrication on various vehicle platforms, I am sure the manufacturer of the frame and RV meet some documented standard somewhere and perform just fine under the intended parameters.
I believe there are two issues, one is the frame flex, most apparent where the tongue meets the rest of the frame. Not much tongue tube extension into the frame, and the attachment method is underwhelming. The other is the fact that the weight of the walls and roof are carried by the outer edges of the floor, which in a few spots are not supported adequately (again, in my opinion).
I intend on addressing these as follows:
I plan on putting an additional 2x4x3/16 wall tube under the existing 5 inch frame tube starting just in front of the waste water pipes and running to the point where the hitch intersects the main frame tube, then bend in to follow the hitch tube which is 2x4 tube. This welded to the existing frame and tongue should suffice in stiffening up the frame and tongue to frame areas. That will add around 350 pounds and raise the trailer around 4 inches. To compensate for that, I plan to order a 7000 (or 8000) lb torsion axle to replace the 4400 lb hybrid that is there today. I need to get into the job to figure out the desired arm rotation of the new axle to net out around 3-4 inches of total lift with frame and larger tire radius. The trailer sits a bit low as built, and while I'm not fond of raising the center of gravity, there would be benefits to a little more clearance when pulling out of sloped driveways, etc.
Along with that, I am going to extend and reinforce the outer front of the trailer where necessary with either more/larger outriggers or equivalent to take the load of the walls and roof a bit better. I think I may have the start of the wall working its way loose from the floor on the passenger front corner, I have to get into it a bit more to figure what if anything needs to be addressed.
If anyone is interested in how this turns out, I will take a few pictures and document my experiences. I have taken information from this forum while exploring the purchase of the RV, if this in some way helps someone then it would be worth the effort to give a little back. If there is little interest I will post an update after the next 5000 mile trip.
This is not a plea for warranty, or an ask of "what should I do". I believe this will continue to be an issue, so I want to "fix" it and increase the safety factor in the process, and this is how I am choosing to address it... your situation may dictate otherwise.
Thanks and happy trails.
