TowPro
- Joined
- Aug 1, 2012
- Posts
- 3,818
OP has not been around since 12/28. guess he is walking, or got it fixed.
It is not SNAKE OIL! I believe he may be referring to this product by Power Service (which lot of people refer to as Diesel Kleen) DIESEL FUEL SUPPLEMENT +CETANE BOOST, which is a winterizer/antigel product.
If you have had a gelling issue you would be using this. I have been using this since 2008, in my first diesel vehicle. My friend who owns diesel trucks for his business has had to deal with gelling issue in the past. When the temps drop to below -0 during the day. This has cost him close to $300 each time to resolve the issue on his work trucks when they gel. The cost includes a HOOK (tow truck) to get the truck into a heated garage from the work site and than replacing all of the fuel filters which are ruined. Plus the service man wages in getting the truck started.
Believe want you want but it is vary cheap insurance against diesel fuel gelling in the winter, especially since most states are mandating 20% BIO-fuel now
if I get this to post...
Gotcha - Gelling issues are quite another issue and I understand your point now. Other than that, the stuff is worthless in most climates but without tank heaters it's a worthwhile precaution especially where the tanks are exposed to chill factors and are subject to Bio Diesel fills.
Not so - forced air over a chilled surface will cool that surface slightly faster; and the faster it cools, the more the latent heat within the contents/attached to the surface will flow out. It's not profound but is measurable. We see it in aircraft fuel tanks at altitude where the gelling when it occurs in the areas with the lowest air pressure (usually the front top surface having the highest airspeed) and is displayed on the fuel tank sensors. These days the fuel is heated in most commercial aircraft but its still not the case in private and older aircraft and certainly was a problem as the world transitioned from gasoline to kerosene in the 50s and 60s. Lear Jets were notorious for this in the 60s.Chill factors only affect humans and animals. Vehicles can’t feel.
yes it may cool faster but it can’t lower the temperature below the temperature of the air. Chill factor refers to the “the feeling” one gets when the wind blows across the human skin.Not so - forced air over a chilled surface will cool that surface slightly faster; and the faster it cools, the more the latent heat within the contents/attached to the surface will flow out. It's not profound but is measurable. We see it in aircraft fuel tanks at altitude where the gelling when it occurs in the areas with the lowest air pressure (usually the front top surface having the highest airspeed) and is displayed on the fuel tank sensors. These days the fuel is heated in most commercial aircraft but its still not the case in private and older aircraft and certainly was a problem as the world transitioned from gasoline to kerosene in the 50s and 60s. Lear Jets were notorious for this in the 60s.
The only state I’ve seen that mandates bio diesel is Illinois. I’ve always avoided buying fuel there. If there are others I haven’t encountered them. From Ohio to Wyoming and Ohio to Florida.
To do what? Isn't that stuff Snake Oil just like STP of the 1970s? We are not dealing with an Ethanol issue here and unless the diesel is being purchased from really old stock (as in years of storage) the stuff is not going to deteriorate as long as its clean. I have never read or seen any science behind any of the diesel additives and very few of the gasoline ones either and given the huge share of wallet/operating cost, I would think there would be lots of fun tests. I do know that Diesel Kleen does nothing to prevent or alleviate the infamous "stiction" that afflicts the Ford Powerstrokes of the early 2000s.
Correct.This is absolutely true and indisputable.
Bruce
Correct.
It's been proven time and time again in the Antarctic there is no 'chill factor' on non living items.
A temperature probe measuring an ambient temperature of -50°F will measure the exact same temperature with a 75 MPH wind blowing across it.
Will things cool quicker with wind blowing across them?.... yes. Will they ever get colder than ambient temperature with wind blowing across them... no.
Only if the object becomes venturi shaped will the AIR become colder.
