Nov 22, 2016 #1 AL Albert1950 Advanced Member Joined Oct 6, 2013 Posts 64 The range hood light and fan plus the lights above the sink do not work. Every other light works. Any troubleshooting help appreciated.
Nov 22, 2016 #2 5picker Campin' - Pickin' - Mason/Shriner RV LIFE Pro Joined Aug 20, 2015 Posts 20,588 Location Allegheny Mountains Have you checked fuses? Are they in a slide? Sometimes the carrier under the slide that holds the wiring and propane lines can have problems and the wires get cut.
Nov 22, 2016 #3 C0 c0nnd0r Tents2RV Joined Mar 28, 2015 Posts 44 Location Virginia Check your GFI breaker. You might be surprised to see what they tied into that circuit. I was.
