dcheatwood
RV LIFE Pro
- Joined
- Nov 1, 2011
- Posts
- 4,510
Anyone who has a class c with oval marker lights on top of the rear wall, check to see if they're mounted correctly. I had two go out not long after buying my 2018. I just got around to replacing them. Found on sale for $13.xx. while doing the work I noticed the two that burned out (led) were mounted upside down. The three still working were mounted right side up. Each lense has a small recess on one edge to pry the cover off to access mounting screws. When mounted upside down, the hole is facing upward allowing rain to get in to the leds. They short and rust out quickly.
Check yours and see if the writing on the lens is upright or not. If not, pop it off, remove the 2 screws, then turn the light right side up and recover.
