Red_Stephens
2025 Forester 2861DS
I'm not impressed with this solar controller, the manual is clear as mud. I'm having an issue with the batteries appearing to be in a low voltage state although the controller shows 12.6-12.8 volts. We were on a weekend trip a couple weeks ago and upon returning I insured everything was off and turned off the battery disconnect. Rig is parked in full sun and I've checked it several times and no issues. However, this morning I went out and after turning on the disconnect I turned on the l/r lights and they were flickering, the fridge came on but showed an E01 error and a LED icon was red and a alarm was beeping, the generator would not even try to start. I started the engine and after a couple minutes the lights stopped flickering, the generator started and the fridge exited fault mode.
Going through the controller manual I found the setting for battery type and it was on GEL, which these are not. They appear to be AGMs, no caps for checking fluid. There is no AGM setting, only GEL, Li, USE, and FLOODED. I set them to USE by process of elimination.
I've checked battery cable terminations and all appear good, no loose ones.
This controller doesn't even show up on the Rlux website.
Any input would be appreciated.
