When I retract the levelers (via All Retract button), my 2025 Europa slides forward 2 - 3 inches. As the levelers start to retract, but still under load, the foot pads shutter and slide forward. Doesn't seem to matter if the ground is level or not, cement or gravel. I generally use Auto Level to put levelers down.
I've not seen this on other coaches, which had HWH hydraulic extend and spring controlled retract, no Auto Level.
1) Why does a vertical retraction cause a forward movement? 2) Seems like a lot off stress on those leveling jacks, which were designed to handle up/down pressure, not forward/backward. Anyone had problems with jack stress (bending or weld cracks)?
