Scan Gauge
Night Stone
Mar 5, 2012
602
Forest Grove, Oregon
Out of curiosity, is the scangauge II any different than a INNOVA 3030 Diagnostic Code Reader for OBDII Vehicles. Does the scangauge do the same stuff as the diagnostic tool? Other than the big difference in price
Perhaps most of us are not familiar with both units.
I have the ScanGauge. It reads diagnostic codes from the OBDII. It also provide 4 different parameter read-outs of things tracked by the ECM. I use it primarily for transmission fluid temperature. I also track volts, water temp, and boost (my truck is turbocharged). The unit will also track mileage etc over time. Apparently it will also measure performance items such as 0 to 60 mph time, 1/4 mile time/speed, but I've never used that feature.
I also have the ScanGauge II, and think it is great.
I bought it to monitor the transmission temperature, but keep track of other engine/transmission functions, also. I monitor the tranny temperature (TFT), the tranny gear ration (GR), the torque converter slippage (SLP), and the current miles per gallon (MPG). Much of the time I am monitoring the mpg functions, trying to maximize my fuel consumption. You can monitor the mpg as current (since engine last started), today, previous day, and tank. You can tweak the ScanGauge to get really close to the actual mpg.....I keep a spreadsheet with the ScanGauge figures and actual figures so that I can get an overall average.
I'm usually trying to MINIMIZE my fuel consumption Chap!! :roflblack:
I will say that the mileage function worked great on my 5.4 Ford. I cannot get it to work well with my 3.5 Ecoboost. I think there is something about the turbocharged nature of the engine that makes it very difficult to calibrate.
Scan Guage
I used scan guage on my 03 blazor. So when I got my truck I hooked it up. A mounth later I got an email form ONSTAR saying it could not give me a reading for my engine. :eek: I may have to use it anyway.
They are completely different animals. The code reader is just that, just to read codes. The Scangauge is mounted on your dash and monitors vehicle parameters, as a bonus it will also read codes. I have the Scangauge II and am very happy with it so far.
Yeah, there are a lot of differences. ScanGauge is a real time performance tool that can read codes. Innova is a diagnostic tool that queries the car's computer.
If I tow and drive, I would get the ScanGauge. If I were doing just repairs I would look further and see if the Innova is the right creature at the right price.
I need to compare the SG to the EDGE CTS...SG is over half the price of the CTS...most likely they do the same except the CTS just has full color screen and some bling which is nice but not necessary for what I want it for.
Hmmmm?
I can't monitor exhaust gas temps on my 6.0L with ScanGauge. There's no X-gauge code for that. I'd need to run a probe into the manifold and use something else.
The ScanGaugeII can only report what the ECM monitors. It is low on bling but it works really well.
Some of the other products (from the links) look really good to. The one product appears to link without needing to route a cable; easier to install and neater. That probably means that it needs to be charged though?
Hmmmm?
Edge has both the Attitude monitor and CS monitor which are cheaper. The CTS is nice if you plan to add a rear view camera b/c it is large enough to give you a good picture. It also nice to have large dials for data output.
Probably the biggest difference between Edge or other diesel specific monitors and ScanGuage and other is that with Edge you can add physical probes instead of relying on the ECM.
I am not sure if you D'max has an EGT probe factory, most diesels do not. So for my Ford I needed to install an actual EGT probe. That meant I needed somehting like the Edge.
I was considering the analog gauge for EGT monitoring & then an OBD II device to monitor ECM data.
Think best route will be an Edge product and their EGT probe for a simpler package (DMAX do not have EGT probe built in).
Edge also allows for boost probe besides camera, etc...
I've been going back and forth on the CTS vs the SG lately. But once you get into the EGT probe and, in my case, a fuel pressure pyro, the cost gets close to $800 for the setup.
For $420 I can get the SG to monitor stuff already handled by the ECM and then just install Extra Gauges for the FP and EGT.
All in the what you are looking for and the money you want to spend. If I had the budget, I'd probably stick to the CTS as it has that appearance factor.
If you are just monitoring MPG, a SG would be the extent of what I'd buy.
SG monitors 4 user selected parameters reported by the ECM. It also has some other convenient items like miles to empty or gallons remaining. I use those to plan my fuel stops while towing.
Once you calibrate tank capacity, MPH the ScanGauge can be very accurate and much more accurate than the panel instruments.
