I have used W-D. It still either jams or falls off the track. Duct tape....that holds my life together.They say, "If it doesn't move and should, use WD-40. If it moves and shouldn't, use duct tape."
Not sure what to do if it does both?
https://www.etrailer.com/RV-Door-Pa...d=npn&gad_source=1&gad_campaignid=21884216313
Carefully remove it clean the side rails. Lube will powdered siliconeCan anyone help me not hate this plastic piece of slider that constantly sticks or falls off?
I was able to get a new one from Amazon which is clear.Can anyone help me not hate this plastic piece of slider that constantly sticks or falls off?
If/when you remove the slider……clean the edges thoroughly.
Then using a toothbrush (hopefully not your partner’s) thoroughly clean both the upper and lower tracks.
After all that, use silicone spray or white lithium grease to lubricate the tracks. Don’t use any lubricants that stay wet and attract dust/dirt.
