Aussieguy
- Joined
- Apr 9, 2022
- Posts
- 6,493
may not be charging cause battery was FULL?
You could also get a stand alone converter "deck mount" ... put it as close to battery as possible
this will remove any bad wiring that slows down the charging of the LFP
A new 120v piece of romex is much simpler and perform better than fooling around with the poor quality of some manufacturer's wiring
it also gives you a backup ... keep the original one in place and just disconnect it from breaker
If the new one eve played up would be a 5 minute job to resurrect the old one
you can go with a HIGHER amperage one too ... get a 55amp model
for faster lifepo4 charging
He has LiFePO4 (Lithium ferro-phosphate) batteries. What you wrote above does not apply.Li-iondoes not need to be fully charged as is the case with lead acid, nor is it desirable to do so. In fact, it is better not to fully charge because a high voltage stresses the battery. Choosing a lower voltage threshold or eliminating the saturation charge altogether, prolongs battery life but this reduces the runtime.
I didn't see this until now. The battery was at 20ish percent at the time.may not be charging cause battery was FULL?
Sorry...but no.the 3 stage
BULK mode appears to be a repair mode for desulfication etc
normalchargeing will be 13.6 which is good enough for charging a lifepo4BUT will be slow
if you want generator charging look at replacing with a more modern converter
