I am having problems with my slide horizontal alignment. The slide is coming in at an angle and is very close to hitting a cabinet, it's has about a half inch clearance. When we bought the RV, it had a couple inches. You can see the slide is coming in crooked when bringing it out and in.
If you stop it half way and measure the two sides, they are about a half inch off. This is a longer slide with two rack and pin tracks on the bottom and one actuating cylinder. I measured the teeth on both tracks (see pictures) and they are about a half inch off.
About a year ago I closed the slide and one of the drawers was open a little and it impacted it. This is when the problem started. When I started troubleshooting I thought maybe there was a sheer pin in this setup, but I don't think mine has that.
I know there is an adjustment bolt on the end of one of the tracks (blue arrow in picture) that I can move, and I tried this but didn't have much luck. The lippert manual for this setup talks about adjusting this, but it looks like it is in the same spot it was when it came out of the factory working normal (paint markings were used)
What is my next step? Could it be possible when the damage occurred that a couple teeth on the track got "jumped"? When aligning these, is it common practice to have to remove the gear portion and manually move the slide a few teeth in or out, and then reset the gear?
