Slide out no power
wmarion
Apr 29, 2017
19
Gastonia, NC
I have 2016 FR Sunseeker 2400S.
I have read most of past post on slide outs and have checked as I could. Camped this week without problems and closed slide out at campgrounds, when got home to clean unit the slide out doesn't work. When I plugged up AC power heard a beep in camper. Did plug up camper prior to trying slide out, When press button for slide out nothing, no sounds, clicking or movement. i checked the fuses and breakers, I have a breaker near floor under the stove that has a 30 AMP breaker. When I flipped that I got same beep sound. The battery checks to be fully charged.
Any ideas? Do you think the 30 AMP breaker would be the one for slide out? I have checked at battery and can't fine a in line fuse,
wmarion
Navy Retired
wmarion
Navy Retired
The slide motor is 12v and has a fuse, not a breaker.
There is a resetable inline fuse close to the battery. It will have a small button on the side. Your slides are 12 volts. No AC breakers involved. you probably held the in button down too long when you closed the slide.
