Have 2024 Isata 3, 24FWSFX. This has a full driver-side slide out. When open the slide out is supporting 2 recliners (more weight when someone sitting there), clothes closet/storage area & 2 food/storage units. When I measure from the ground up (on a flat surface), the outer portion of slide is at least an inch closer to ground, i.e. sagging.
I'm concerned over time this is going to create issues with the slide working properly.
Does anyone recommend or have comments about using slide out supports to level the slide out to minimize pressure on slide vs. sidewall? These are readily available on Amazon and not expensive.
Thank you in advance.
Datsdad
Datsdad
