Solar Power & Battle Born batteries.
This is a one year update of my FR3 Solar install project.
Past threads:
I have been work on fine tuning the system. While the Samlex did measure the Battery & Solar amps, But it did not show a SOC. My addition was a Victron BMV-712 battery monitor.
The next improvement was to upgrade to a Victron SmartSolar MPPT 100/50. The EpEver MPPT was purchased from Amazon. The seller was from China and support was by email only. The EpEver Lithium bluetooth app was not available on the Google Play store. I had to email support to get them to send it to me. I think they sent me the beta version because it was not released on Google Play until March 2019.
I decided to replace it with a Victron SmartSolar MPPT 100/50. The Victron MPPT also work with the Victron BMV-712. The Victron bluetooth app works a lot better than Epever. It also raised the possible MPPT output to 50 amps, the maximum of the Samlex EVO-2212 solar interface.
2018 upgrades Recap:
2018-2019 winter
I found out even on a sunny day I never saw more than 365 watts from the 600 watt solar array. I decided to order more solar panels for the roof. I calculated that the 50 amp solar charge controller could output about 730 watts. (50a x 14.6v = 730w) Since I have my solar panels are flat and not angled to the sun, they will never output at full power.
I had four more 100 watt Renogy Solar panels installed in Feb 2019. This brings the total up to ten. Output is still limited to the 50 amps of the Victron MPPT solar charge controller. I have circuit breakers to protect MPPT. I will install a 2nd solar charge controller if needed. I modified my SIG to 800 watts to reflect that is the maximum wattage I expect from the solar panels.
2018-2019 winter upgrade Recap:
My next post will be about April 2019 to present.
Past threads:
- Expanding compartment space for 2200 Watt Inverter/Charger.
Thread Started 04-27-2018
- Samlex EVO-2212 Inverter/Charger (May 2018)
- 4ea -100ah Battle Born LiFePO4 batteries (May 2018)
- 6ea - 100 watt Renogy Solar panels (June 2018)
- EpEver TRIRON 4210N 40 amp MPPT Solar Charge Controller with bluetooth (June 2018)
- Victron BMV-712 (July 2018)
- Victron SmartSolar MPPT 100/50 (August 2018)
2018-2019 winter
- Solar panel over sizing for rigid roof mount
Thread Started 08-17-2018
- 10ea - 100 watt Renogy Solar panels (April 2019)
