Splendide Dryer TVM63X not working.
Gullywhumper
Nov 14, 2022
8
Palo Alto
We have a 2021 Georgetown 36D. The dryer was running and then stopped mid cycle. Breaker was not tripped. I turned the breaker off and waited 5 minutes anyway. Vent screen is clean. I check the electrical outlet with a circuit tester and it has power and wired correctly. The dryer only has an on/off switch and a high/low temp button. I cannot find a reset button. The washer has power and works. I talked with Splendide and they said it is probably the thermostat; need to remove the dryer; thermostat is at the back of the dryer. Warranty has expired. Appreciate all ideas before I remove the dryer.... THX
Moved thread from the Tech and Repair section to the Motorhome section's Georgetown sub-forum for better help from other Georgetown owners and possible factory support.
Thanks. How do you check the door switch?
Haven't done it but you might try and closing the switch with a screwdriver and see if the dryer will turn on. Looks like the switch could be removed (carefully) and checked for continuity. I am sure the mfg. could be of more help.
