Storage not using bumper
DDC
Sep 26, 2011
2,680
Komoka Ontario
I wanted to be able to take my generator and gas but not in my TV or in the TT so this is what I have done, I raised it so I would not have to house the battery, access to the battery requires removing four nuts but no big deal although I may add a cut-off switch later.
you just gave me an ideal. can you post pictures of how you mounted the box and some info on it.
I used 1 inch perforated steel tubing from ( home depot or loses or similar place) 3/8 th threaded rod cut to the length needed ( mine was 8 pieces 8 inches long) for the carrier I used 1.5 angle 1/8 thick ( I would have preferred alum. but was expensive here) cut to size , I needed 4 pieces 6 inches long to clear the battery, two pieces the depth of the box and one piece for front and back of box. Bolted together with 5/16 bolts and ny-lock nuts and flat washers, the box I got from costco it's a tradesman 21, I had to alter the lock to suit my set-up. It took longer to plan than it did to put it all together, hope this helps as I did not take pictures as I was putting it together.
