I have a Cedar Creek 36 CKTS with a Suburban SF-42Q furnace. It worked properly until we had a nearby lightening strike and the motor would just run continuously. I took it to the dealer they advised it was the control board which was replaced. When I picked it up it seemed to run properly. However, we went out recently and I found it would run for 3-5 minutes then the burner go out and unit would try to restart three times before shutting down. It would actually fire each of the three retries but quickly shut off after 3-5 seconds. I removed the heater and checked the limit switch. It was closed, as it should be. Obviously, the sail switch was working properly since the start sequence always works. The burn chamber looks like new with no obstructions. Since it does initially start and run for some time, it must detect the flames' presence. It seems that the unit works fine, then just runs out of propane and tries the restart sequence. I'm stumped, I can only think it is either the regulator (all other propane appliances operate properly) or there is something wrong with the flame detector part of the process. Any help would be appreciated.
