Hi. The propane flame goes out after a minute or three minutes. Flame looks large when on. Checked for webs. Electric water heater runs good.
Have 2013 Rockwood Signature Lite.
Does the heating element run on electric? Or any other causes?
Do you have electronic ignition or pilot light?Hi. The propane flame goes out after a minute or three minutes.
Also, my pilot light goes out every few minutes in my stove.
How long has camper been siting? May have obstruction in gas jet area. Check for dirt from mud dubbers and or spiders . Later RJD
Okay. Not into explosion. Thanks.It is possible that you are having problems with your regulator. My first check would be to get a manometer to check the pressures at the tank (11 inches on the water column) then regulator out put. (should be on regulator) Then check the appliance.
If you have dirt and crud you can clear the lines with compressed air. NOTE: propane is heaver than air and will puddle in low lying areas. With the proper mixture of air it could explode. Make sure to leak check all joints before calling the job done.
If all pressures check good it may be a flame verification problem and you should have a certified tech. look at it.![]()
Sounds right to me. Or those OPD valves on the tanks.It is possible that you are having problems with your regulator.
