larry2c
As I mentioned in a different thread my old GC batteries are tired (6+ years) and I am replacing them with a pair of 165AH LiFePO4 batteries. After weighing my options I have decided to put the batteries in my pass-thru and put a box on the old battery tray that will hold the camping chairs and table that will be displaced.
Back when I installed the solar panels I mounted my solar charger inside the pass-thru so my thought is to use that same bulkhead panel for this upgrade. I'd like some suggestions - maybe with some pictures - of a clean way to route the wiring for all the pieces on the front wall like the CC is mounted so I don't have any penetrations in the front of my TT. I would also like feedback on the way I have the GC batteries, charge controller and battery monitor wired up in regards to if it is "proper" for use with the LiFePO4 batteries. One thing I am not sure of is the shunt for the battery monitor - could it be mounted on a board in the pass-thru or do they actually generate heat and would possibly be a fire risk?
So here's a couple of pictures and diagrams. The CC wiring diagram is how my current system is wired in. FYI - I went with a PWM controller back then to save money but I'm thinking of upgrading it to an MPPT controller now or not far in the future. The battery monitor I have is in a screenshot and I know it's a cheapy but it works fine and the CC and now the batteries themselves have BT monitoring so I'm intending to stick with this monitor. Last is a picture of the "bulkhead" with my charge controller, fuse and solar panel cut off switch.
Any thoughts on what I have along with suggestions for my upgrade would be appreciated!
