Switches not labeled, what do they do?
shemeantwell
Mar 21, 2025
3
pennsylvania
We just got a 2015 FR Premeire, the main switch has on/off, but there are switches all over interior, mostly fat ones, not labeled what they even control. Not hooked up to 30 right now, none of them seem to be turning anything in. I know check the battery. I’m more asking can anyone show me a diagram what each switch controls through camper? My husband can figure out getting battery to work if that’s the issue. I want to know what switches all over camper control what.
Can you be more specific on your RV model? I assume a premiere may be a Rockwood brand? Do you know the actual model number so we can maybe connect you with others who have same? Thanks
You probably won't find an electrical diagram. They simply don't exist. You may get lucky and someone here has the exact make/model and can tell you what each switch does.
Best bet is to plug it in and try each switch to see what they do. They likely won't work without the RV being plugged in.
X2 not enough information but your best bet is to try them next time that you are plugged into electric. Even pictures would help.
Might mostly be lights but not only on a switch some may have a switch on each fixture,
Good Luck !
:signhavefun:
My suggestion it to treat it like an escape room. Power it up so you have both 120VAC and 12VDC. Test each switch. Also look at the fuse panel and note what each fuse powers. Do the same with the circuit breakers.
Find the GFCI outlets with reset buttons and test them to determine which outlets are protected by them.
I believe they OP has a Rockwood Freedom popup. Therefore moved thread from the Tech and Repair section to the Tent Camper and Popup section for better help from other Popup owners.
OP, it's important to post what model number your Popup is and pics are often more helpful than descriptions.
Unfortunately such diagrams don't exist. That's why pics and your popup's model number are so important.
Yes I’m sorry, I forget they are very specific. It’s a 2015 forest river premier 2716g.
Thank you for moving this, I didn’t realize there was a better place. I have seen a diagram of where electric
Lines are and they all look Greek to me and would help for repairs more than I just have a bunch of switches and just wondered if I could connect with someone with the same camper.
You might get a quicker response if you did a search on your model number, in this sub-forum. Then you can PM others that own your model number for help.
I agree with TacomaJoe approach, create your own list of which switch and breaker controls what. I have an exterior light I still haven't found the switch for after 2 trips. More lack of details by the manufacturer.
