The coffee dilemma
tyler811
RV LIFE Pro
Apr 1, 2018
606
Set up is below with a portable power supply which is 999 Wh. Did out first boondocking trip over the weekend in northern Mi. Temps in the 20's at night with sunny 55 in the day. Batteries were at 100% when we set up at 4:30 pm and 82% at about 8 am. Running tank heating pads, furnace, no lights, instant on hot water heater that entire time.
In the morning I turned on the inverter and made a pot of coffee. Between the inverter and coffee pot, I lost 22% more of my batteries making one pot of coffee.
The coffee pot is rated at 725 watts and running a 2000 watt inverter. The wife bought a percolator for the stove top but I don't want to use that in the summer.
Suggestions for my JAVA fix?
We were using a Coleman stovetop coffee maker which works well but takes a long time with the stove going. Recently switched to a simple pour over and using a teapot to heat the water. Takes much less stove time and makes good coffee.
Any solar?
I’m camped on the south side Lake Superior
Installed two solar panel and they replace the power I use at night the next day
Got 2 panels @ 370w 740w total $350
Plus a 50amp MPPT $85 charge controller
Another $100 for crimps wires etc
Been off grid for 4 days no issues
No inverter using percultator on stove
But will invest in a inverter next
I think you're finding out through personal experience that resistive heat is super-duper power-hungry (and I hope you're turning the coffeemaker off as soon as it's stopped dripping). The inverter isn't helping, and probably gobbling 10% in converting 12v to 120.
If you want a fresh pot of coffee, you're basically limited to (1) an electric maker, (2) a stoptop (or firetop) coffeepot or percolator (think also, portable white gas stove or backpacking stove running on coleman fuel), or (3) a large scale pourover (takes time and hot water - and is basically what a drip maker is all about).
All of the above have their advantages and disadvantages, pretty clear to figure them, too. For what it's worth, we did switch our drop pot from the glass carafe to a thermal carafe - brew a pot and the carafe does the work of keeping the coffee warm (as opposed to the hot plate). Coffee tastes better for longer, too, because it's not being cooked.
For the summer, I might recommend a pre-made jug of cold-brew. You can drink it iced all day long (nice in the summer, esp if you don't have AC). And if it's at room temp, you can nuke a mug up to hot-coffee-standard for way less energy than making a pot of fresh. Plus, it'll be super smooth coffee.
If you don't want to go any of these routes, Starbucks Via instants are almost reasonable, just add a mugful of hot water (instant hot water to the microwave). And, if money is burning a hole in your pocket, there are "instant" portable espresso makers for the camping/backpacking set (but now we're chasing a different animal).
Just my .02. Hope this helps.
X2
Tea kettle heats up quick. I use an Aeropress. Be sure to preheat the coffee cup.
One of these days I am going to try the pour over method.
Both are a bit more time consuming than a coffee maker but what else do you have to do? Relax.
I've used a MyJo for K-cups, a Coleman stovetop drip coffee maker and an Aeropress system for French press ground coffee.
Never needed electricity.
There are a number of easy options.
percolated coffee tho :facepalm:
Note: I'm not so snobby as to turn my nose up at *perc coffee in camp*, as *perc coffee in camp* is better than ANY other coffee ANYwhere else. Which is why the camp stove + perc coffeepot became a part of my go-to carcamping gear for decades. Nothing quite like getting up earlier than anyone else, firing up the stove and brewing up a pot while the rest of camp is quiet.
...but it's not my preferred method for a nice smooth well balanced cuppa.
Cheers.
:trink25:
Set up is below with a portable power supply[/URL] which is 999 Wh. Did out first boondocking trip over the weekend in northern Mi. Temps in the 20's at night with sunny 55 in the day. Batteries were at 100% when we set up at 4:30 pm and 82% at about 8 am. Running tank heating pads, furnace, no lights, instant on hot water heater that entire time.
Either use a Coleman type stove outside or do it inside. A temporary shot of heat in an RV in the morning, even in the Summer, isn't a big deal.
Or, buy a cheap lifepo4 for 150 dollars and connect it to the power station. There are lots of videos depicting how to do it.
Stovetop propane is likely the cheapest & least power usage.
I bought a couple low wattage items a little while back for off grid camping. A single slice 500 watt toaster and a collapsible (silicon top) 600 watt electric water kettle. Frequently, I’ll just have instant oatmeal & toast for camping breakfast and those will cover that. They cover instant or drip coffee, too, or a coffee press.
percolated coffee tho :sick:
Note: I'm not so snobby as to turn my nose up at perc coffee in camp as percolated coffee in camp is better than ANY other coffee ANYwhere else. Which is why the camp stove + perc coffeepot became a part of my go-to carcamping gear for decades. Nothing quite like getting up earlier than anyone else, firing up the stove and brewing up a pot while the rest of camp is quiet.
We have done the same thing for years with our Coleman camp stove. The smoothness of the perked coffee beats drip and K-cup methods IMO. It takes longer, about 15-20minutes, but in that time I'm preparing breakfast. Once it starts boiling, let it go for 6-7 minutes, and Bob's your uncle.:)
Cheers.
:trink25:
LOL thanks, didn't know you could test percolators :trink39:
Sure. Do you have LP on board? Use the cooktop and a coffee pot. Gas is always a much more efficient heat producer than electricity. As to summertime, the cooktop won't heat the inside enough to notice.
Bob
Cheers.
:trink25:
Nothing like a stout cup of "Cowboy Coffee" early on cool frosty morning! :)
