Having issue with theater seats. No power can't find fuse no idea where to look. Seats are stuck down cannot look at wires? Any help would be greatly appreciated.
It always helps if you posted the year, make and model number of your RV.
Did you look at your fuse panel? Bad fuses usually light up and if it is 110 there might be a tripped breaker. Can you see where they are plugged in?
Yes looked at fuses no luck. They are 12 volt recliners. Cannot locate fuse can't see under them as I cannot raise foot to get at wiring? They also have USB buit in to arm rest no power there either.
If I could recline them manually im sure it is probably an inline fuse.
If I knew manufacturer of recliner I could Google them.
