Tire clearance on Microlite 23FB
Rhigh
RV LIFE Pro
Jul 2, 2019
7
Ok, so I thought I might need to replace the axles on my 2011 23FB, so I remove tires to get varies measurements for new axles and find there is no evidence of rubbing on the fender well. There is however rubbing on the very front edge of the fender well. The geometry of how this can happen confuses me.
Does anyone with a 23FB want to give me an idea of the tire clearance of your rig.
Thanks to all
Moved thread from the Tech and Repair section to the TT/5th Wheel section's Flagstaff sub-forum since the OP is asking for model-specific information on a Flagstaff product.
Have you checked the springs?
Also, the axel might be bent and causing the problem.
Thanks for your reply.
The axles are torsion arm so no springs.
I've reached out to forest river, they said I should have 4 to 5 inches of clearance. I'm researching dexter replacement axles as the AlKo axles are discontinued. I can't find any information on the start angle required.
