OK folks Tireman9 here. Sorry I did not jump in earlier but I was out of the country.
Lets see if I can summarize: First there are a number of things to consider such as type of vehicle and if tires are same size & type as OE. Lets stick with the tires being same as OE. If you don't understand a term please go to my blog where I have a lot more space to cover items in detail.
Motorhomes and other vehicles that can be driven. The tires on these vehicles rotate around a centerline that points to the center of a turn radius. (See Ackerman).
All Radial tires do have Interply Shear. but it's the level of this force that is significantly different for vehicles that do not have steering Ackerman i.e. trailers.
The Interply Shear that tires in trailer application can be 24% higher than identical tires on a motorvehicle with active steering.
Increased inflation (lower load) is something the driver can do that would lower this 24% but not to 0%.
So what inflation should motorvehicles run? As a minimum they should run the same inflation on all tires on an axle. This is done to keep steering or turning response similar when turning right vs left. They also should run
at least the inflation necessary to support the load on the heavier end of the axle.
The 4 corner weight is a method used to learn the actual load on each end of each axle. This measurement should be made when the vehicle is loaded to the heaviest ever expected.
So knowing the heavy tire you use the charts to learn the MINIMUM inflation for tires on that axle.
I do recommend a minimum of +10% inflation over that minimum to address day to day pressure variation due to weather (temperature and barometer) changes. I have covered this in my blog with my personal experiences of driving my Class-C across country a couple times.
Well I hope I clarified my position. If not you can email me (email is posted on my blog under my picture.
