Science says 100% nitrogen in passenger applications is worthless which is why no tire manufacturer says to use it.
Where did I ever say it was needed. The fact a tire CAN lose pressure due to permeation is what I was addressing and that is fact, not internet myth.
FWIW, automotive tire manufacturers DID investigate the possibility that using Nitrogen inflation might reduce tire failures in hot climates like the SW. Tire failure rates in those areas were high due to heat and the fact people just didn't maintain tire pressures. That pretty much stopped when self service gas replaced full service gas stations where air pressure was checked for free with every tank fill.
Wasn't just the warranty rates in the SW but also the infamous Ford Explorer/Firestone tire failures with fatalities that caused the interest.
It ended up that just mandating TPMS on light trucks and SUV's, and eventually passenger vehicles, reduced the problem enough to go no further with Nitrogen "non critical applications".
Also a sigh of relief from most of the 28-29 thousand tire stores in the US that are annually installing over 200 million replacement tires. No need for them to to purchase equipment to supply Nitrogen that can cost thousands. ($3,000-$20,000 depending on amount minute flow rate)
Same for auto dealer service shops.
Some have added the equipment and offer it as an added profit center and enough are "biting" to keep the machines "generating".
Want to have some fun?
Buy one of these for over $300 and check the Nitrogen percentage in your regular air filled tires over the next couple of years. According to a large supplier of Nitrogen generators to the tire industry, in a personal conversation with Company's president, regular testing like that will show the Nitrogen percentage to increase. Of course they don't publish that fact as they sell the generators
